What could thump when hitting a pothole?
Old Jan 16, 2008 | 05:17 PM
michaelt's Avatar
Default What could thump when hitting a pothole?
With what I have done to my JK ( see sig) basically OME kit, what could cause a thumping noise upon hitting a large pothole or such an obstacle? Could it be the normal shock noise? Any input would be appreciated.
Old Jan 16, 2008 | 05:31 PM
hiteck's Avatar
What do you consider a large pot hole?
What speed are you traveling?
Did you install longer shocks or shock relocation (extenders) braskets?
Old Jan 16, 2008 | 07:13 PM
jetsfan28's Avatar
The door latch mechanism has been known to cause a thump like sound over bumps. Ajusting the striker plate seems to remedy the issue.
Where does the sound seem to come from?
Old Jan 16, 2008 | 07:33 PM
cormac827's Avatar
i would be willing to put money on the fact that it is the bumpstops...how far are they apart?
i have the tf 2.5" bb and i have the same issue
Old Jan 17, 2008 | 04:24 AM
seal20's Avatar
I second this....bumpstops are most likely the culprit
Old Jan 17, 2008 | 05:55 AM
michaelt's Avatar
It comes from the back of the vehicle. It sounds like the jack is loose ( it is not) or the rear seat isn't latched ( it is)
The Bump stops are way away even at full flex so i don't think it is that. It could be the door latch , I will look at that
Old Jan 17, 2008 | 05:59 AM
bim6180's Avatar
Hmm, interesting. i've experienced this exact same thing...going about 25 mph on the back road, and hit a large potholes. I've never really figure out what it was. BTW, i have RE 2" BB kit with shocks
Old Jan 17, 2008 | 06:25 AM
roddogg's Avatar
Default check front axle
Just my .02, Several treads here and other places about bad left front ujoints. I caused my axle flanges to break.
Lift the front off the groung by the frame and check it out. My only be the bump stop but why not be sure.
Old Jan 17, 2008 | 06:27 AM
4JEXEP4's Avatar
I would second this. Go over a bump that makes the noise and then turn around and go over the bump again but this time open your door a couple of inches if you don't here the sound then its the latch if you do hear it then its something else, you can try this with all the doors with the help of a friend. I had to adjust all four of my doors for the thud sound and now its perfect.
Old Jan 17, 2008 | 10:59 AM
RMEF_lifer's Avatar
Assuming you have the spare on a bumper mounted carrier, could be coming from that.
