35 tire on factory tire carrier. Will it fit?
Old Dec 18, 2012 | 06:05 AM
nicco's Avatar
Default 35 tire on factory tire carrier. Will it fit?
Getting some falken ats for christmas and want to know if i can keep my existing tire carrier or will I have to buy a new.
Old Dec 18, 2012 | 06:09 AM
manamal's Avatar
I don't have 35s but i've researched 35s on this forum at great length. It should fit, but ultimately it's the weight that is a problem. Most say that you should start saving for an aftermarket tire carrier and try to only keep the 35 on your tailgate for a short period of time, and certainly throw it in the jeep while your wheeling. Can damage the tailgate, hinges, etc.
Old Dec 18, 2012 | 06:10 AM
SiliconTi's Avatar
Nope - too deep. There is a vendor that sells and adapter, but common opinion is that the tailgate is not strong enough and the metal will eventually fail. Get a carrier.
Scallywag's Avatar
It will fit, but the added weight of it will not make your jeep happy!! After a few potholes and bumps, eventually those spotwelds holding your tailgate together will begin to give out!
Old Dec 18, 2012 | 06:18 AM
Nwapache's Avatar
To be clear: to run 35"s you need correct backspacing, which will not allow you enough depth on the carrier bolts. This means you need a $50-$70 adapter for your tire carrier to mount the spare.
Once that hurdle has been crossed, you now have to deal with the weight penalty on your tail gate. Given time and mileage, your tailgate will slowly succumb to the forces of gravity. So do this as a temporary solution.
Old Dec 18, 2012 | 06:34 AM
Ryan0260's Avatar
X2. It will work for a while but more than likely will be an issue
Old Dec 18, 2012 | 06:37 AM
djcamis's Avatar
It could work fine with a smaller 35 such as a BFG AT but the falkens ats are heavy as crap! so it could fail faster. Had no problems with my BFG at on my stock tire carrier . Other with BFG mud terrains have had no issues as well.
Old Dec 18, 2012 | 06:42 AM
OR-FAB's Avatar
Sponsoring Manufacturer
OR-FAB
Check out OR-Fabs tire carrier that can hold up to a 37" tire without changing the factory bumper. It has a mount for a hi-lift jack and a cb antenna. It comes in 3 options; 85208 Tire only carrier, 85207 tire can carrier (has room for 2 5 gal gerry cans), and 85209 RotoPax carrier (comes with 2 3gal RotoPax.)
ID:	399614Click image for larger version
Name:	CAN CARRIER JEEP JK.jpg
ID:	399615Click image for larger version
ID:	399613Click image for larger version
Old Dec 18, 2012 | 06:46 AM
Krawlersaur's Avatar
This is correct. You need the right backspacing to push it out. Ive had mine on my stock carrier for a long time. Take it off while not on pavement. Dont want it bouncing around. When i go off road, I strap it down in the back.
Old Dec 18, 2012 | 06:58 AM
TheTerminator's Avatar
Not true. I go through sea of pot holes at around 30-40mph or more on logging roads, without issues. I'm not saying it will not fail after some years of hard use, but definitely not after "a few potholes".
