Your thoughts on setup idea
Old Dec 25, 2012 | 06:18 PM
jrphillips's Avatar
Default Your thoughts on setup idea
Here goes. '12. JKU sport. I want to put a 3in lift kit or leveling kit on and put 33's on my stock rims. Do I need anything else? Spacers? Fender trimming?
Old Dec 25, 2012 | 06:23 PM
JKZinger's Avatar
You will if you put on a 3" lift kit. New Driveshafts on a 2 door and front one on a 4 door.
Old Dec 25, 2012 | 06:24 PM
MSmitty's Avatar
You will need spacers or stock rims will rub. 1.5" work well.
Old Dec 25, 2012 | 06:26 PM
Otisnruby's Avatar
From my understanding what's posted on the forum, you may need spacers with the 33's but no trimming on the fenders will be needed.
Old Dec 25, 2012 | 06:42 PM
chaz14_9's Avatar
I have 33s with a 4 in lift kit for a JKU. No drive shaft needed. No spacers either.
Old Dec 25, 2012 | 06:44 PM
chaz14_9's Avatar
Here is a side shot
Biggy's Avatar
3" lift is to much for 33" tall tires. Stick with the leveling kit.
Old Dec 25, 2012 | 06:47 PM
Biggy's Avatar
You have aftermarket rims and therefore dont need spacers. He wants to run stock rims. So to the OP you will need wheel spacers.
Old Dec 25, 2012 | 09:00 PM
river2c's Avatar
Here is a side shot
The OP has stock rims so he will need spacers. He also has a 2012 which will likely require a new front drive shaft with a 3" lift. I'd go with a smaller lift or leveling kit with 33s.
Old Dec 25, 2012 | 09:11 PM
XJ Jay's Avatar
Don't waist your money on 33s on a JKU, just get 35s. You'll regret 33s with in months, especially with a 3" lift. 2 doors can pull 33s off but the Unlim is just to damn big for 33s.
