power tank mounting options??
Old Jan 18, 2008 | 09:19 AM
silverbullet31's Avatar
Default power tank mounting options??
I have a powertank PT10 but I dont havea bracket for it. How is everyone mounting theirs? Are you mounting them to rollbar or to the floor or on the fenderwell? Thanks
Old Jan 18, 2008 | 10:03 AM
kb7our's Avatar
I've got mine standing up in the cargo area behind the rear seat passenger side headrest with one strap looped around and under the regulator guard and clipped to each side of the sturdy headrest mount and another strap near the bottom of the tank clipped to the cargo hoop located where the back seats folds down. Very sturdy setup. With a 25' coiled hose no need to remove the tank to air up.
On another note with regard to CO2 refills I never realized that the larger liquor stores that refill kegs or home tap CO2 tanks can do the same with the PT for $1 per lb maybe less. I found a liquor store to be more convenient then locating a CO2 refill station. If you can weigh tank before and after to see how much fit otherwise you are likely to be charged for 10 lbs when only 7 fit. I use a small handheld battery operated digital fishing type of scale also sold by PT.
Enjoy!
Old Jan 18, 2008 | 10:13 AM
Mini-me's Avatar
Default Mounting CO2 Tank
I mounted my 15 Lb CO2 tank like this with the clamps from "Power Tank". The clamp part numbers are "ABC-2450" for black or "ABC-2350" for red.
Old Jan 18, 2008 | 11:25 AM
JacksJeep's Avatar
With a bracket, you can mount a tank here if you have a hardtop.
Old Jan 18, 2008 | 02:17 PM
I have a soft top will the roll bar mount work? And if it will work will I have to cut the roll bar padding out so the clamps will fit? Thanks for the help
Old Jan 18, 2008 | 06:51 PM
kb7our's Avatar
I like your setup! Maybe I will change to that arrangement. What holds the jack in place and what is the PT bracket secured to?
Old Jan 20, 2008 | 01:17 PM
Engine553's Avatar
Now that's a nice set-up...Nice install
Old Jan 20, 2008 | 01:19 PM
x2, really looks cool
Old Jan 25, 2008 | 08:07 AM
bracket's Avatar
what mounts are you using to mount to the roll bar? http://www.powertank.com/products/productID/75 Are they the TJ Roll cage mounts? WIll they work on the JK as well? Thanks
Brian
