Upgradeable lift kit?
Old Jan 11, 2013 | 07:54 AM
vitodivita's Avatar
Default Upgradeable lift kit?
Hello,
I've been tossing around the idea of lifting my Jeep & going with 35" tires. I'd like a 2.5" lift. Is it possible to get a basic 2.5" lift now, then add a long arm kit to after the fact? (Excuse my newbieness, despite having this jeep for a year and stalking forums forever, I still have no clue) It would ease the pain of the purchase.. I'm narrowing it down to Teraflex or Rock Krawler.. Opinions?
Old Jan 11, 2013 | 08:04 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
Originally Posted by vitodivita
Hello,
Almost anything is upgradeable.
Teraflex and Rock krawler both have long arm upgrade kits. On both kits you can run anyones coils or shocks
Old Jan 11, 2013 | 08:11 AM
vitodivita's Avatar
So I could combine this Teraflex 1251000 - TeraFlex 2.5" Lift Kit with Shocks for 07-13 Jeep® Wrangler Unlimited JK 4 Door - Quadratec
with
Teraflex 1955000 - TeraFlex Long Arm Upgrade Kit for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec later on?
Old Jan 11, 2013 | 08:31 AM
EVO MFG's Avatar
Sponsoring Manufacturer
yes, it'll work fine. I would look into trackbar brackets or adjustable trackbars depending on how much lift you actually get.
I believe RK also has a 2.5" long arm coming out.
Old Jan 11, 2013 | 08:34 AM
vitodivita's Avatar
Would you mind linking me to those? I'm pretty set on a 2.5" lift, but I want to start with a basic lift and upgrade later for budgets sake.
Old Jan 11, 2013 | 08:37 AM
Rock Krawler Suspension's Avatar
Former Vendor
EVO is absolutely correct!
With us, you could easily start with anyone of our standard 2.5" coil spring systems and then grapht in a long arm upgrade!
Our 2.5" front coils are progressive rate for better ride quality and better off-road performance!
There are alot of differences in the long arm upgrades.
Our X Factor Long Arm Upgrade features independent 3 link conversions front and rear for bind free articulation as well as unparralled ground clearance! All of our control arms are made from solid alloy steel and feature our Abuse Proof Lifetime Warranty!
Give us a shout if you have any questions. We love to talk Jeep. Good luck with your build!
RK
Old Jan 11, 2013 | 08:49 AM
vitodivita's Avatar
Thanks for the replies..
I'm envisioning a 2.5" RK Stock mod system, & then throwing in a front swaybar disconnect...Does that work?
With a lift I want to have more clearance to get over the bigger obstacles and get on the more advanced trails..No rock crawling in my area..
Old Jan 11, 2013 | 09:08 AM
Former Vendor
The 2.5" Stock Mod system comes with disconnects...
That sounds like a reasonable plan. Then you could simply purchase a long arm upgrade and a few other components to complete our 2.5" X Factor Long Arm System!
RK
Old Jan 11, 2013 | 09:10 AM
vitodivita's Avatar
RK
Ha like I said, I'm clueless about this stuff. I'm planning on a purchase in about a month or so. I'm very happy that I can build this slowly & not have to fork out a ton of cash at once.
Old Jan 11, 2013 | 09:11 AM
TeraFlex's Avatar
TeraFlex 2.5" coil kit w/shocks. Now you will want the #1955020 2.5" long arm upgrade kit, it uses straight rear lowers for better clearance over the #1955000 kit.
