Does any one use AEV bade for stock scissor jack.
Old Jan 19, 2013 | 07:24 PM
tkkim's Avatar
Default Does any one use AEV bade for stock scissor jack.
My jku is 2.5 lift and 34' tire..
I bought my bottle jack from harbor freight, but even it could not lifted my tire from ground...
So does any one use aev base for stock scissor jack to lifted jk?
Or recommend me some other jack that can be used to more than 2.5' lifted jk..
Floor jack is good.. But i'm living at apt.. So.. I don't have garage...
Old Jan 19, 2013 | 07:31 PM
afpilot82's Avatar
JK-Forum Ambassador
Seriosly?!? Please tell me this is a joke. Read your other jack thread you started 3 hours ago, several people chimed in recommending the AEV jack base.
Old Jan 19, 2013 | 11:12 PM
Brightwhite's Avatar
Our society has been infiltrated by this twitter and Facebook kind of language. It's sad...it really is.
I can't understand any if this, jack!
Old Jan 20, 2013 | 05:35 AM
G I JOE's Avatar
In case you have trouble finding your other thread, here is a link to it.
https://www.jk-forum.com/forums/modi...r-jack-261099/
Old Jan 20, 2013 | 06:18 AM
Ncb's Avatar
Ncb
The stock jack will work on a Jeep with 34" tires. The axle tube on a Jeep with 34" tires is only one inch taller than a Rubicon model. A square of 2X4 under the jack base will help.
Old Jan 20, 2013 | 06:22 AM
Ncb's Avatar
Ncb
Do you need the use of a jack for removing wheels or for jacking the frame to do suspension work?
Old Jan 20, 2013 | 08:35 AM
LidLess07X's Avatar
I Have the jack base. Used with 37s on flat ground no problem. Also stows away nicely in the rear cubby
Old Jan 20, 2013 | 08:48 AM
k0260's Avatar
yes sir, works great. Especially hand in snow,mud or sand. A simple must have.
Old Jan 20, 2013 | 10:11 AM
Cavallini03's Avatar
You have 34 foot tires? How do you fit those with only 2.5 inch lift? You must have serious rubbing..
Yes the AEV jack base is great. But you should jack from the axle, so even if you have a lift the stock one should work.
Old Jan 20, 2013 | 10:54 AM
GJeep's Avatar
The guy wants to replace a 34 foot tire, but the JACK is his problem ?? ...
