Nitro sleeves worth it?
Old Jan 20, 2013 | 01:48 AM
jksearles's Avatar
Default Nitro sleeves worth it?
I'm looking to move up to 37s in a year or so once my 35s are done and I want to beef up my stock 30. Will the nitro sleeves be that big of an upgrade to keep the 30 safe. I don't do alot of heavy offloading right now but I def will eventually. It's a DD and I'm kind of trying to build it up slowly with what I can little by little. I know the evo weld ins are good but I don't have a welder and I want something I can do myself. I just want to make sure that the nitro sleeves will actually be worth the money and actually do something
Old Jan 20, 2013 | 04:18 AM
mstrofpuppets's Avatar
I installed them in my Dana 44 and I believe they are worth the time and money. There is no way for me to test how much they added to the strength of the axle. I did weld the ends of the tubes to the axle tube. Not sure if that helped but will keep them from moving and a little added insurance. The thought behind sleeves making your axle tubes stronger makes sense. You won't be able to tell they are in there when driving. I also added EVO gussets to my axle as well. If you are keeping the d30 I would look into gussets and an axle truss if you want 37s. Hope this helps.
Old Jan 20, 2013 | 08:24 AM
k0260's Avatar
I have Nitro sleeves. Some believe they're not fully needed as they add only 30% more strength to the axle. Wayalife mentioned he thought they were blown out of proportion as far as being a must have. They don't run sleeves on their Rubicat's D30 on 37's either.
Old Jan 20, 2013 | 08:31 AM
familytime's Avatar
JK Forum Regional Rep
We run them,as we wheel hard sometimes.
Old Jan 20, 2013 | 08:36 AM
matt1171's Avatar
Rubicat doesn't have a D30. It's a Rubicon therefore it has a D44 up front.
Old Jan 20, 2013 | 08:44 AM
k0260's Avatar
oops, in any case, no sleeves up front from wayalife... so sorry
Old Jan 20, 2013 | 12:12 PM
mistasparkl's Avatar
I got the nitro sleeves in my 30--they're cheap insurance, and an easy install.
Old Jan 20, 2013 | 12:20 PM
Maertz's Avatar
Id say there worth it by far. Mine went in easy and feel alit better about the axle strength.
Old Jan 20, 2013 | 06:20 PM
brian.243's Avatar
Any one know if you can run rcv axles with nitro sleeves.
Old Jan 20, 2013 | 06:26 PM
bob-o's Avatar
I'm sure u can if they are only 27 or 30 spline. I just installed 30 spline rcv's in my rubi the other day and I have the evo magnum sleeves
