Where will it rub?
Old Jan 20, 2013 | 06:57 PM
SDBoxer's Avatar
Default Where will it rub?
I have read so many threads on this topic and seen the stickies, but I can't seem to find what I'm looking for.
I just installed a 2.5 TF lift and put 285/70 17 Duratracs on my 2dr Freedom Edition. I bought spidertrax spacers, but haven't put them on yet. I like the look it has now without the spacers, nice and flush with the fenders. I don't rub at all on the street. How bad will I rub when disconnected and where? Fenders? Air Dam? Sway Bar Links? Thank you and sorry if this has already been posted.
Old Jan 20, 2013 | 07:01 PM
k0260's Avatar
Before I had spacers and had rubbing issues, the contact was made on the sway bar sides, and or the lower control arms, when full turning.
Old Jan 20, 2013 | 07:12 PM
SDBoxer's Avatar
Was that disconnected or on the street? Thanks
Old Jan 20, 2013 | 07:15 PM
k0260's Avatar
Just simply full turns while connected rubbed. No rubbing occured else where at full flex disco'd.
Old Jan 20, 2013 | 07:28 PM
SDBoxer's Avatar
Interesting, so if I don't have any rubbing whatsoever now, do you think they will rub when disco'd and the suspension cycles?
Old Jan 20, 2013 | 07:31 PM
k0260's Avatar
Couldn't say. Depends on your lift, disco's, tires, you'll just need to try it and see.
Old Jan 20, 2013 | 07:52 PM
gunbo75's Avatar
When i installed my 285/75/17 tires I rubbed at full lock.
Old Jan 20, 2013 | 09:12 PM
zstairlessone's Avatar
Pictures of the lift n tires with no spacers -please!!
Old Jan 20, 2013 | 09:30 PM
river2c's Avatar
Your rear sway bar links are probably dangerously close to your stock tires/rims now. Spidertrax spacers or aftermarket wheels with 4.5" or less backspacing are needed.
Old Jan 20, 2013 | 09:49 PM
BlackRockBurner's Avatar
TF 2.5 coil is a great package. In time it may settle, but not by much if any. Kind of muddy but the wheels do not go past the fenders. 275x75x18 Cooper STT w/Spiders
If memory serves, TF states minimum of 4.5 backspace so the wheels will not rub the suspension at articulation. I think the rear. With 35s the wheels could rub the inner flares at full drop. I too was leery of spacers at first, but if you install those Spiders correctly, I wouldn't be concerned. Ran this setup for 3.5 years and 80,000 or so miles. Not only will your rig feel more stable on turns, but you will get a very nice stance.
