AEV Lift Help!!!
Old Jan 21, 2013 | 12:53 PM
FOSTER's Avatar
Default AEV Lift Help!!!
I have a problem after installing the 4.5" lift with it drifting or swerving. I have loosened and retightened all of the bolts under the Jeep, ran higher air pressure, lower air pressure and had the front end aligned. Any suggestions of what I should check from here? The jeep has 29000 miles on it.
Old Jan 21, 2013 | 01:04 PM
madmike232's Avatar
I am no expert and I hope someone can chime in but did your replace your pitman arm? I know my buddy did a 6 in lift was having a similar problem turned out to be his pitman arm . I hope that helps
Old Jan 21, 2013 | 01:13 PM
little_cornball's Avatar
Was reading up on aev lifts on there website. Could have swore they wrote that if you add a pitman arm that is not part of there package it will not be conducive to the tune of their lifts. You may have luck checking there website or give them a call for some assistance if you believe it is the lift.
Old Jan 21, 2013 | 06:21 PM
FOSTER's Avatar
Think we have it figured out. I replaced the ball joints when I installed the lift which is causing the steering issues. The ball joints are tight and need to wear in and the steering should loosen.
