Sway Bar links for a 5.5 inch lift???
Old Jan 20, 2008 | 07:30 PM
tshuelsman's Avatar
Default Sway Bar links for a 5.5 inch lift???
Just installed my new lift... 4 inch coils with 1 inch spacer in the rear and 1.25 i the front.. Eather way i had the Skyjacker sway bar links but there not long enough now that i have this lift.
What is everybody using with a lift bigger than 4inchs???
JKS?
I will post Pics of the new lift once i can get some day light....
Old Jan 20, 2008 | 07:52 PM
tshuelsman's Avatar
Here is a Pic from my PHone.... not very good quality but all i got right now...
and if that doesnt Work ... This will
Before.....
http://good-times.webshots.com/photo...82580300zQCJZv
After
http://good-times.webshots.com/photo...82580300qDyNwl
Old Jan 21, 2008 | 06:10 AM
tshuelsman's Avatar
I need some help somebody has to have a suggestion.
Old Jan 21, 2008 | 06:24 AM
BaltChief's Avatar
Currie makes some adjustable for up to a 6" lift...
Old Jan 21, 2008 | 06:36 AM
Mini-me's Avatar
Default Sway bar links
You can use Curries links off their RockJock JK 5.5" lift.
http://www.currieenterprises.com/CES...t.aspx?id=2875
If you need some manual disconnects for the front or just like their design better Rock Krawler (up to 6" lift) makes some.
JKS also mkes manual disconnects for the JK for up to 6"
I have a Rubi and I use Curries on the front and rear of my JK. They are well made and are durable.
Old Jan 21, 2008 | 10:23 AM
Ctimrun's Avatar
I've got the Currie lift which has 5.5" in front and I use JKS quicker disconnects. David at Northridge set me up with the proper length discos for the lift.
Old Jan 22, 2008 | 12:30 PM
tshuelsman's Avatar
Default JKS or Currie
Does anybody have any pictures of ther Currie Sway bar links installed or Pics of there JKS links ????
debating on spending 69.99 or 130.99.. on links...
Old Jan 22, 2008 | 02:13 PM
David @ Currie Ent.'s Avatar
Former Vendor
You can also see some other pictures here
http://www.project-jk.com/wp-gallery...2_itemId=35881
