Arb O.B.A underhood problem
Old Jan 27, 2013 | 12:57 PM
BIGNICK's Avatar
Default Arb O.B.A underhood problem
I purchased the 2012 arb underhood package from northrigde. Everything was there when I opened the box and the bracket fits flush and all the way down under the hood but the compressor is to big height wise. Any ideas I tryef to make it work 3 separate times I was thinking maybe I got the wrong model compressor. Also for those who have use the compressor in there jeeps the wiring diagram says to splice a wire into the ignition wire. I was curious why and I know another wire goes into the acessory for the light of the button
Thanks in advanced nick
Old Jan 27, 2013 | 12:59 PM
BIGNICK's Avatar
Pics to show its doesn't fit
ID:	414846   Click image for larger version
ID:	414847   Click image for larger version
ID:	414848   Click image for larger version
Old Jan 27, 2013 | 02:26 PM
David M's Avatar
I haven't installed one in a while but I seem to remember the cylinder(s) being able to spin to configure in many different ways. There should be a way to loosen them up and spin them in such a way to where it will fit.
Old Jan 27, 2013 | 05:07 PM
BIGNICK's Avatar
appreciate it ill look into that thanks
Old Jan 27, 2013 | 09:26 PM
fifthconspiracy's Avatar
Yeah, you have to spin the aluminum cylinder around to the front.
Like this:
Cheers! ~ Paul.
