Teraflex Leveling Kit and Quick Disco Pin
Old Jan 31, 2013 | 12:23 PM
jnsport12's Avatar
Default Teraflex Leveling Kit and Quick Disco Pin
I recently put on a TF Leveling Kit and see that the sway bar links where included. Has anyone had any experience with using the Teraflex Quick Disco Pins in these sway bar links? See pics below.Click image for larger version
Name:	Screen shot 2013-01-31 at 6.47.30 PM.jpg
ID:	416717Click image for larger version
Name:	Screen shot 2013-01-31 at 6.47.56 PM.jpg
If it works it could be a great workaround and save me some $$$, if not I'm probably going down the JKS Quick Disco route.
Pictures would be helpful as well.
Old Jan 31, 2013 | 01:56 PM
blue project's Avatar
I used the discos from the kit...less than year later, the bushings were gone. Gone like nit there because they broke apart. I bought a set of jks discos. Greasable and adjustable. Worth the money.
Old Jan 31, 2013 | 02:26 PM
jnsport12's Avatar
Thanks definitely helps, leaning toward jks but tf pins easy fix instead of taking out stock bolts each time I go off road.
Old Jan 31, 2013 | 02:53 PM
Get the jks discos. Just pull the pins and go. Not bolts to undo or anything like that. Expect to pay a 150. They are adjustable if and when you get a taller lift!
Old Jan 31, 2013 | 08:02 PM
Whiskeymike's Avatar
With the JKS, they have pins at top and bottom. Does that mean you pull the pins and take the whole link out and store it? Therefore no flipping up and securing it? Or chance of it coming loose and running into axle?
Old Feb 1, 2013 | 01:21 AM
Exeactly. There are mounting posts you install. Then its pull the pins, remove the entire link, then to be safe put the pins back in. Ill see if I can't get a pic.
