Replacement springs leveling kit question
Old Feb 11, 2013 | 08:23 PM
stagedtrip's Avatar
Default Replacement springs leveling kit question
I have 18/59 springs to replace my 15/54s, and teraflex leveling for my 2 door X. My question is when I install these will my stock shocks still be kosher or do I need extensions or get a set for a 2" lift set up?
Old Feb 11, 2013 | 11:31 PM
hooper's Avatar
You should put on extensions or lift shocks for 2"s of lift. If not you will limit you down travel.
Old Feb 11, 2013 | 11:41 PM
revvinkevin's Avatar
It's probably not best but I haven't done anything to my shocks and swapped in the 18/58 spring combo on my 2 door. It seems to flex ok and it works great on the trail.
Old Feb 12, 2013 | 12:37 AM
stagedtrip's Avatar
Im not sure what the total lift is gonna be with the springs and leveling kit but id assume at least 2"...
Old Feb 12, 2013 | 12:40 AM
jadmt's Avatar
JK-Forum Ambassador
I would install every thing and see what the actual lift ends up.
Old Feb 12, 2013 | 01:06 AM
stagedtrip's Avatar
Probably will do that
Old Feb 12, 2013 | 05:04 AM
Ryan0260's Avatar
Sounds like a good excuse to replace the not so great factory shocks. If you actually get 2" of lift, you will ideally want longer shocks. I'm not a huge fan of extensions, but it would be better than trying to run shocks that are too short.
Old Feb 12, 2013 | 05:24 AM
stagedtrip's Avatar
Id rather do some aftermarket blistens than extensions, was hoping someone had done this same thing, cheap easy way to lift a bit
