Which set of control arms and driveshafts?
Old Feb 16, 2013 | 09:16 AM
krawzdogg's Avatar
Default Which set of control arms and driveshafts?
I currently have a Rubicon Express 3.5 inch lift on my 2013 2 door. For obvious reasons, the driveshafts need to be replaced , I was leaning towards Adam's driveshafts, but from what I have read they don't come with new front yokes and you reuse the stock one (correct me if I am wrong). Now I am leaning towards Tatton's driveshafts.
I figured I better replace the control arms as well to adjust the caster and pinion angles and hopefully prevent any driveshaft vibes (If I would of known this before deciding on a lift, I would of purchased them with the lift , live and learn I guess.) I was planning on purchasing all 8 but all the sets are slightly out of budget (except the Rough Country X Flex set, opinions and reviews on them would be great). So I guess my question is will I notice a difference between having all 8 compared to just the lower front and upper rears?
I have read every post on this forum and I am still confused. Any input/recommendations on driveshafts and control arms would be great to help me decide. Maybe a vendor can offer me a crazy deal on all of it that I just can't refuse
Old Feb 16, 2013 | 09:19 AM
k0260's Avatar
you'll have much better flex with all 8 arms. I'm really happy using Rock Krawler and Currie arms.
Old Feb 16, 2013 | 09:51 AM
river2c's Avatar
I replaced my front drive shaft with a Coast and have been very happy with it. I have the front and rear RK lower control arms. If you replace the rear drive shaft, you will need the rear upper control arms to adjust the pinion angle.
Old Feb 16, 2013 | 09:57 AM
shockwaveaz's Avatar
I run Tereflex driveshafts and metal cloak arms. Watch this video
http://youtu.be/8dE_tFFvjfU Sent from my SPH-L900 using Tapatalk 2
Old Feb 16, 2013 | 10:07 AM
krawzdogg's Avatar
Metalcloak's Duroflex Joint Revealed - YouTube
Thats a great video! Now if only I could get a great deal on them. Definitely out of my budget otherwise.
Old Feb 16, 2013 | 10:11 AM
I can understand that. I didn't buy all eight at once. I started with the front lowers and rear uppers.
Old Feb 16, 2013 | 10:14 AM
I can understand that. I didn't buy all eight at once. I started with the front lowers and rear uppers. This also has some good info. Compares them to other arms.
http://youtu.be/qN4TpL-LwJQ?t=17s
Old Feb 16, 2013 | 01:40 PM
Gman*2007's Avatar
If you have factory drive shafts on a 3" lift, is it okay to change out just the front and rear lowers? I thought you didn't need to change out the uppers unless you had after market shafts.
Old Feb 16, 2013 | 05:53 PM
Since you wouldn't need to adjust your pinion angle you would be correct.
Old Feb 16, 2013 | 06:32 PM
HiHoSilver's Avatar
Subscribed because I'm in the same situation!
Sent from my iPhone 5!
