Spare tire rattle
So I recently upgraded my tires to 305/70 r17 Terra's. I knew going in to this decision that there was going to be some rattling probably. Sure enough there was a rattle so I got some larger tailgate bump stops. The rattle is a little better but still there, and I can actually see my spare tire vibrate when I go over bumps. My question is, how concerned do I need to be about the spare tire moving around/rattling. Second, is my only option left to buy a tire carrier? Thanks.
Did not want to hear that... Well now the search is on for a good tire carrier. I like the look of the AEV one or the LOD. Anyone know anything good or bad about these?
It's your top hinge on your gate I would suspect. Stand by the spare and hit the top sidewall of the tire from behind, you'll hear the rattle at the top hinge. That's what happened to my 08, My 2012 I installed a Teraflex hinged carrier. I'm not taking any chances, I'm getting the weight off of the gate.
Honestly other than the more expensive one being adjustable which you don't need that's all I can think of lol. There's a video on YouTube about the tereflexs tire carrier and it explains it very well. Check it out
The cheaper one you will need to re-use your current tire carrier mount. The more expresive one comes with a aluminum mount that allows the tire to be moved in or out and up and down depend on what size tire is used.
