Stock Coil Spring Numbers?
Old Feb 21, 2013 | 03:08 PM
newjkman's Avatar
Default Stock Coil Spring Numbers?
I would like to have the part numbers for the stiffest, tallest factory coil springs for my 2D 2013 JK.
Thanks!!!
Old Feb 21, 2013 | 03:14 PM
jadmt's Avatar
JK-Forum Ambassador
Thanks!!!
fronts are 52126319ac for the back look at your tag on the rear coil and replace the 56ac or whatever the last 2 numbers and 2 letters with 60
Old Feb 21, 2013 | 04:22 PM
OH9JK's Avatar
JK-Forum Ambassador
Front p/n 52126319AB
Rear p/n 68004460AA
Old Feb 21, 2013 | 04:28 PM
JKingAround's Avatar
I have 4 door rubi springs for sale $100
They fit stock 2 doors and will give you 2" of lift
Old Feb 21, 2013 | 04:29 PM
15-16 front
59 back
Old Feb 21, 2013 | 04:51 PM
Gman*2007's Avatar
I have some 18's fronts & 59's back, if interested.
Old Feb 21, 2013 | 06:18 PM
jbry311's Avatar
Will one set make a sport sit higher than the other? I was thinking of getting a bb lift but if rubicon springs will lift me 2 inches I'll just do that.
Old Feb 21, 2013 | 07:39 PM
jadmt's Avatar
JK-Forum Ambassador
look at your stock springs (there is a tag on them) if the last 2 numbers are under 17 ie 14, 15 or 16 ending in ab or ac then if you get springs ending in 19ab/ac you will get a little lift. if you already have 17 or 18's you won't get much. Rubicon springs have nothing to do with it. Sport 4dr with hard tops and automatics and tow package should have higher numbered springs any model can have the same springs from the factory. heck many rubi springs are 14's so purely luck of the draw when it comes to springs.
Old Feb 21, 2013 | 07:41 PM
jadmt's Avatar
JK-Forum Ambassador
I think when you see some jeeps they have the real bad rake it is because they have like 15 or 16 in front and 58 or higheer in rear. Mine came with 17 and 58 and was level.
Old Feb 22, 2013 | 06:44 AM
Your logic is flawed. My jeep did not have a bad rake. Rubi springs are stiffer than stock sport spring. That's why they come with 32s and can fit 35s with flat fenders. You can't say that about sports.
Stock pic
A rubi unlimited springs sit over a 1" taller than a sport unlimited with out including tires and will give over 2" on a 2 door.
