Soft top
Anyone having problems with there soft top leaking on there 2011 jk up on the top corners of the door. I know it sounds stupid cuz it's a jeep but I wanna fix it lol it I also leaking through the door levers thanks
Leaking through the door levers sounds like a more serious problem than the top. That means that your doors are not sealed and there may be water getting in them. I have no idea what a fix for this would be, but if its still under warrantly bring it to the dealer and have them check it out. But no, my doesn't leak a single drop. (Knock on wood).
Leaking from the doors I have no idea. But the top corners maybe I can help. It it leaking while the doors are shut?? I know when I wash my jeep it don't leak. But when I open the door it lets the water run around the seal. Which after I shut the door I get a couple more drops. Now if ur getting more then that check ur foam. Check to make sure top is put on correct. Hope this helps
