Rear track bar mount broken!!
Old Mar 3, 2013 | 05:03 PM
RedFox's Avatar
Default Rear track bar mount broken!!
So I was casually driving the other day and heard a loud thump. My rear track bar mount had broken off the axle!! It broke due to the added leverage of the lift kit it had installed on it (a simple bracket that attached to the oe mount to raise the mounting point),
Any suggestions for a replacement? I'm thinking of calling up offroad evo tomorrow to get it done as well as adding rock skins and maybe sliders..
Old Mar 3, 2013 | 05:13 PM
jaker t5's Avatar
Mine did that to , first welded it back up and broke again
Second time grinded off the stock mount and custom made a mount been good ever since
There are a few company's that make some nice ones off the top of my head metal cloak has a sweet one
Old Mar 3, 2013 | 06:16 PM
Atch's Avatar
Can't tell for sure from the pic, but you can try and use a trackbar relocation bracket like what EVO offers
Old Mar 3, 2013 | 06:33 PM
Smashboogie 4x4's Avatar
Former Vendor
This is a common problem. You will find some lift companies producing a track bar with a bracket that will be bolted to and surrounding the stock mount. At that point you also weld the relocation mount axle to prevent that from happening.
Here is a picture as an example.
RK Rear Track Bar Mount
Old Mar 3, 2013 | 07:47 PM
Justinn407's Avatar
Here's a pic of my new Artec truss and track bar bracket.. Good stuff.. Bomb proof..
Old Mar 3, 2013 | 10:13 PM
Steeperjeeper's Avatar
The same thing happened to me driving from Maine to Va but it was in the front track bar bracket.
Old Mar 4, 2013 | 06:11 AM
lkjk's Avatar
Is this a common problem due to the relocation bracket or even with adjustable trackbars and no bracket?
Old Mar 4, 2013 | 06:17 AM
kjeeper10's Avatar
Vet Army
Mounts like Teraflex have additional mounting spots,
Track bar mount/axle and lower control arm bolt.
I believe they only require welding if doing extreme off roading.
Old Mar 4, 2013 | 07:41 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
its common with a bracket designed like whats pictured, Give us a ring!
Old Mar 4, 2013 | 11:12 AM
RedFox's Avatar
Originally Posted by Justinn407
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=429416"/>
Wow, I really like that. I might end up going that route, looks sturdy!
