Horsepower on the cheap
Old Mar 7, 2013 | 07:58 AM
Mjf1107's Avatar
Default Horsepower on the cheap
I have a 2010 jk love the look hate the baby motor in the hood. Is there any turbo or super charger out there that is not going to brake the bank ??? Or is there anything other than aor intake i can do to inprove my hp?
Old Mar 7, 2013 | 07:59 AM
kjeeper10's Avatar
Vet Army
Auto/man, tire size ?
Have you looked into regearing the differentials ?
Old Mar 7, 2013 | 08:01 AM
jk_sea's Avatar
It's probably cheaper or easier to trade up to a 2012 which comes with the 285hp 3.6.
Superchargers are available for the 3.8...there's a couple guys running them here on the forums. They can tell you more about cost and headache more than I can.
I owned a 3.8, although it was a 2-door. It was slow, but it was a good motor and got the job done, on-road and off-road.
Old Mar 7, 2013 | 09:25 AM
BigSteve's Avatar
How much do you have to spend? Doing forced induction on the cheap will only lead to problems down the road.
Old Mar 7, 2013 | 12:22 PM
Mjf1107's Avatar
Probably around 1000 but i dont want future problems... How will forced air induction damge my motor?? Just curious not being an ass
Old Mar 7, 2013 | 12:24 PM
RyanW's Avatar
It's cheaper and safer to just upgrade to a '12+. Any forced induction runs the risk of blowing up the motor.
Old Mar 7, 2013 | 12:51 PM
JKingAround's Avatar
Your looking at 5000 for a turbo. But it will give you all the power you want.
Old Mar 7, 2013 | 12:53 PM
Mjf1107's Avatar
255/85/16 standard dont really know a whole lot about regearing
Old Mar 7, 2013 | 04:00 PM
Smashboogie 4x4's Avatar
Former Vendor
Forced induction that is not done right will only lead to the potential for leaning out the engine and causing detonation. Running an engine to lean will melt the pistons. Even if you have the correct AFR (Air Fuel Ratio) you still run the risk of running to much boost and blowing a head gasket.
The best way to add forced induction is to lower the compression ratio and add in boost. It will make way more power than running the little amount of boost that you can (safely) with a normally aspirated engine.
Old Mar 8, 2013 | 04:11 AM
Mjf1107's Avatar
Thanks for the help
