Smoked Lights
Old Mar 15, 2013 | 08:20 AM
JeepinCreepin's Avatar
Default Smoked Lights
Ok so here is my question.......... How do you smoke the lenses of your tail lights and the side marker lights on the front fenders? Is there somewhere that I can get clear side marker lights?
Just incase i have a '09 Rbicon Unlimited if that makes a difference.
Thanks
Old Mar 15, 2013 | 08:26 AM
NaptownJK's Avatar
h t t p://item.mobileweb.ebay.com/viewitem?itemId=190810220551&index=0&nav=SEARCH&ni d=68651180589
Old Mar 15, 2013 | 09:50 AM
TristanWomack's Avatar
Use plasti dip. It blacks then out and you can still see then. They also make a smoke color that is translucent.
ID:	434287   Click image for larger version
Old Mar 15, 2013 | 09:51 AM
Both of those "then"'s were suppose to be "them" oops haha
Old Mar 15, 2013 | 09:58 AM
Trugz's Avatar
Take a look at my gallery and you will see what I did. I purchased tint spray in a can and did thin coats on the lenses until I reached the desired level of darkness. Make sure you check your state aws in regards to tint lenses. You can get the tint spray at Advanced Auto or Autozone.
Old Mar 15, 2013 | 10:45 AM
topdown89's Avatar
Did you do the rear lights too?
Old Mar 15, 2013 | 10:55 AM
Jumpmaster's Avatar
VHT Night Shades seems to be popular.
Old Mar 15, 2013 | 10:57 AM
janders82's Avatar
Ummm, don't use PlastiDip!!!
VHT Night Shades is what you want - it's a translucent paint
Works awesome! I'd say about 3-4 light coats does the trick. If you go too dark, just use some acetone to remove it and try again
Old Mar 15, 2013 | 11:29 AM
Collyn's Avatar
VHT Nightshade sucks too. It's not very glossy. Looks kinda milky. I use DuPont clear with a little black basecoat mixed in. About 10-1 clear/black. Then pass it till it is desired darkness.
Old Mar 15, 2013 | 12:23 PM
Thats exactly what I am looking for! Those look good!
