EVO Mount w/ Big ARB Compressor?
I'll let you know after this weekend. I'm at the same stage you are basically except I have a couple of It's installed for tire inflation and pressure gauge. I located the Solenoid holes facing forward for what it's worth
Mounted mine like this, found it was the only orientation for it to work with solenoids, air line to gauge, air hose attachment.
Attachment 436089
Attachment 436090
Attachment 436091
Attachment 436089
Attachment 436090
Attachment 436091
This one
I was thinking about adding a manifold that runs forward and then mount my solenoids onto that and plug the rest of the holes.
This one Attachment 436093
I want to add it srictly for solenoid orientation. Just wondering what others have done with theirs. I think it would work if I ran that manifold forward, parallel to the brake reservoir. then mount the solenoids to the top and the quick release for the tire hose at the Fwd end.
The way I have mine oriented, the solenoids fit just fine, with the tire hose coupling, and I also added an extra tee for my air gauge. Its a tight fit, but it all works with no interference. Just play with it spinning the manifold around, etc.
