Price of balljoints, gussets & sleeves
Old Mar 21, 2013 | 05:41 PM
Whiskey Bravo's Avatar
Default Price of balljoints, gussets & sleeves
Hey guys. Once again I can't believe my local mod shop... Are these quotes correct for parts and labour??
Synergy Balljoints ~ 800$
Gussets and sleeves ~ 800$
In both cases i was told it could go higher if the install was difficult due to seized nuts or slightly bent axle...
Is it just me or...
Old Mar 21, 2013 | 05:47 PM
JK-jeepit's Avatar
Is it just me or...
I had Desert Rat quote me Gussets and sleeves (Teraflex) at $770 installed and tax included
I have been told by a buddy that the Synergy ball joints would be ~$800 to install...
so it looks pretty good.
Old Mar 21, 2013 | 05:51 PM
Cheers, thanks
Old Mar 21, 2013 | 05:52 PM
c4bus's Avatar
Synergy BJs are 250, so they're quoting you 350 in labor for that, Cs are about 30-60 depending on the company and will only require minor welding once everything is tore down to the BJs, and sleeves varry in both price, and time for installation, I know Terraflex sleeves require drilling and plug welding, which can add some labor.
In my opinion, they should charge you the parts and labor or the BJs, add the Cs for an extra 100, then the parts for the sleeves and maybe an extra hour of labor. With Cs and sleeves, everything will already be disassembled because of the BJs, the labor should be minimal.
Old Mar 21, 2013 | 05:56 PM
Interesting... Hadn't thought of the synergetic install... Pardon the pun
Old Mar 21, 2013 | 06:00 PM
c4bus's Avatar
Doing separately I'd say those are good prices, but if you do them both at once I'd ask the shop for a deal on the labor.
Old Mar 21, 2013 | 06:02 PM
JK-jeepit's Avatar
Good point... it would make sense to do both these upgrades at once.
thanks
good post op..
Old Mar 21, 2013 | 06:27 PM
Jumpmaster's Avatar
As far as labor goes; i paid my local shop $700. That was for synergy sleeve and gusset, install of alloy ball joints, TF diff on the front, and exhaust spacers. My goal for Phase I was to get the front Dana 44 beefed up at one time and out of the way.
Old Mar 21, 2013 | 06:46 PM
JKJon's Avatar
Paying $550 in labor to get evo sleeves/gussets and synergy balljoints installed
Old Mar 21, 2013 | 06:49 PM
See now that sounds perfect!
