RK Traction Bar Oreintation
Old Mar 22, 2013 | 12:50 PM
korps's Avatar
Default RK Traction Bar Oreintation
I know it goes to the axle but does the removable part go towards the front or rear of the vehicle thanks
Old Mar 22, 2013 | 12:58 PM
jeffj's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=436951"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=436952"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=436953"/>
Do you have two of those inserts? You need one on each side. I think that's what your asking.
Old Mar 22, 2013 | 01:01 PM
Flat Top's Avatar
If you are talking about the insert that goes inside the joint, then there should be two of them, one for each side of the joint.
Old Mar 22, 2013 | 01:02 PM
korps's Avatar
That's what I figured I can't find the other one thanks brotha
Old Mar 22, 2013 | 01:03 PM
korps's Avatar
Checking boxes fingers crossed everything is off already
Old Mar 22, 2013 | 01:08 PM
korps's Avatar
Found it good thing I saved the boxes thanks guys it a straight mount with no rubber bushings right?
Old Mar 22, 2013 | 01:38 PM
jeffj's Avatar
Yes, good luck with the install. Orientate the bend to the rear to clear the diff.
Old Mar 22, 2013 | 03:21 PM
Cuv's Avatar
Cuv
I had tried doing this and it put the bushing side in a bind. Fixed it by having a friend move the mount back. Well, not the mount but welded a piece just behind the existing mount so now it's back an inch or two. No problems clearing anything now.
Old Mar 23, 2013 | 04:13 AM
olyelr's Avatar
You should not have had to make a new mount for it to fit.
And it is a track bar, not traction bar. Close in name, but totally different in purpose.
Old Mar 23, 2013 | 03:40 PM
Cuv's Avatar
Cuv
It's probably more due to pushing the axle back a little, but it rubbed the coils, not the diff. I may be able to find a pic to show what I'm talking about. It had rubbed the passenger side coil pretty bad.
