ARB air compressor not working..need help
Old Mar 24, 2013 | 01:09 PM
inspect-a-home's Avatar
Default ARB air compressor not working..need help
Everything is all hooked up, rocker switches wired, unsure of air pressure sensor wiring and two wiring for the dash.
When I turn the switch on I get nothing. Any assistance appreciated
Old Mar 24, 2013 | 01:13 PM
are these wires correct?
Old Mar 24, 2013 | 01:14 PM
Are these wires correct on air sensor?
Old Mar 24, 2013 | 01:16 PM
Hammerstien's Avatar
Do you have a volt meter?
Old Mar 24, 2013 | 01:17 PM
Is it required to use the dash wiring?
Name:	Dash wiring.png
Old Mar 24, 2013 | 01:18 PM
Ive got a lilttle instrument that beeps when you put it near an outlet..
Old Mar 24, 2013 | 01:20 PM
DJCFHB's Avatar
yeah you need to use those wires. one is power and one is dash lights. That should complete the circuit and have everything running.
Old Mar 24, 2013 | 01:22 PM
Originally Posted by DJCFHB
yeah you need to you those wires. one is power and one is dash lights. That should complete the circuit and have everything running.
sweet...where do they hook up to and where are they?
Old Mar 24, 2013 | 01:42 PM
DJCFHB's Avatar
I dont remember which color is for what ( 12v power and dashlight) but one need to be plugged into a 12v power source and the other to dashlights. I used the cigarrette lighter on the left for the ignitioned switched 12v power source and used a volt meter to find a wire for the dash light.
Old Mar 24, 2013 | 01:46 PM
did you have to remove bezel or is there one just under or near the steering column?
