Axle seal post regear 07 2dr JK
Old Mar 26, 2013 | 05:04 PM
jimmradd's Avatar
Default Axle seal post regear 07 2dr JK
Just trying to cover my bases... Just had my 2dr regeared and noticed that I have a front driver side axle seal leak, at least that's what it appears to be... They had to remove front axle shafts to regear right? That's what I have read on different write ups. I guess I should have done a little more research before hand but they should have replaced the seals? I noticed a leak on the pinion seals, both front and rear and they are going to replace those... Just from the sounds of it they should've replaced seals and didn't, it would make sense to me to replace them but just as they say common sense isn't common to all.
BTW the thing rides a hell of a lot better now so I can't complain about that.
Old Mar 26, 2013 | 05:12 PM
CajunTiger's Avatar
Yes they did have to remove the axels to regear. They should have changed out the seals also. If not, thats why its leaking. They should have used an overhaul kit with seals and bearings, thats called a master overhaul kit. If they did use an overhaul kit, they might have screwed the seal putting it on. If they didn't use a new kit, they will have to now.
