Evo rockstar skid
Anybody have the bolt on EVO rockstar LCA skids? The ones that relocate the rear shock mounts.
How do you like them? What shocks are you running? Pros/cons?
I have them and like them fine. I have a Rock Krawler 2.5" Max Travel Pro suspension with the recommended Bilstein 5100 shocks. I use Teraflex 2.25" bump stop extensions in the rear to keep the shocks from over compressing and to keep the tires out of the body.
This is the exact answer I am looking for. Not having 2k at my dispense I am slowly piecing out at RK max travel kit. First track bar and tie rod, then LCAs then brake lines, then coils. I have a BB right now and I'm adding/upgrading as funds permit. When I saw these skids I thought it would be a great addition
Rear shock relocation is a must if you see rocks. Those are very nice skids and the set up you are working towards will give you a nice build!
PM Us if you have any questions or need any quotes on anything at all.
I forgot to mention that I also use Teraflex .5" rear spacers with the dongle and hose clamps around the bottom of the rears. Thanks for the reminder.
