Please help
Old Apr 8, 2013 | 02:04 PM
fitchottie's Avatar
Default Please help
I don't know what todo.. currently have a stock 2013 jkus with 17"
i hooked up with some AEV and BFG but i am not sure if I want to go to 35" with 3.73. my options are as follows
35" BFG KM2
or 315/70/17 Duratrac
(5 AEV Pintlers) Argent or black
2.5xt lift , geo correction, and Procal, Teraflex exhaust bracket
4200 for everything.... out the door... end all be all
or
(5) pintlers
(5) Cooper 285/70/17 atp ( 949.00) Installed
no lift... Possible Teraflex leveling kit or if I can do the same with rubicon stuff... I don't know If it's possible
Then Gobi Roof Rack system, qucik discos... extc
We want to start camping, and this will be a daily drive... with Minimal wheeling..
HELP.. I am all over the place with options.
Old Apr 8, 2013 | 02:19 PM
Sscarbrough52's Avatar
You will regret not lifting, your going to have to re gear so be it. You will not have to re gear right away unless you live in a hilly area and if you have a 6sp, you may not at all. I have that lift and will be getting those tires after I wear the stock Rubi some, I did some extras like adj Tracbar and replaced all bolts for the CA. I have Xd Spy wheel 17x9 with 4.53 offset. It drives great but know I will re gear once I go with 34.5" tires.
Attachment 444483
Old Apr 8, 2013 | 02:29 PM
Twinkydog's Avatar
Have you been or plan to go to uwharrie? A stock height jku will drag it's belly over almost all of the water breaks. Doesn't do any damage, but is anoying enough my wife said " Thats enough, go buy your lift".
Old Apr 8, 2013 | 02:33 PM
fitchottie's Avatar
I would like to.. but would a leveling kit not fix that?
Old Apr 8, 2013 | 03:32 PM
Gman*2007's Avatar
Do the 35's. It is doable with the auto and 373. If not you will be disappointed later.
Old Apr 8, 2013 | 03:40 PM
Twinkydog's Avatar
I honestly have no idea, only been there stock. Put on a 2.5 lift and 37's Saturday, headed back down there this weekend and I bet she doesn't drag. There were some guys down there last year with a leveling kit and 33's. The first ledge going up Daniel was real bad. I turned around and went the other way after having to watch them get hung up and have to be drug over the ledge. I did run all of the other trails stock with my JKUR.
Old Apr 8, 2013 | 06:05 PM
JK Inspired's Avatar
NO brackets, keep stock wheels, 19/60 coils and shocks, and then play it by ear n
Old Apr 8, 2013 | 10:00 PM
RubiconRon's Avatar
I have 35s with the auto and 3.73. It's fine, as long as you reprogram for the tire size.
Old Apr 9, 2013 | 12:08 AM
Huggerls1's Avatar
315 duratracs and 373. Not sure why anyone thinks they would need to regear.
Old Apr 9, 2013 | 01:46 AM
GJeep's Avatar
We often forget how capable is a stock Jeep.
For minimal offroading and some camping, 285/70/17 would be fine, and you don't need a lift.
Just make sure they're All Terrain, rated for load D or C, NOT load E.
In time, you'll learn your exact wishes/needs.
You may get hooked on offroading... and there's a lot you can do with a stock Jeep and these tires.
I'd get some basic recovery equipment, 'just in case', and a compressor (can be a small, portable one) for re-inflating.
