teraflex leveling kit springs or pucks/spacers
Old Apr 10, 2013 | 06:29 AM
apolanish's Avatar
Default teraflex leveling kit springs or pucks/spacers
Getting 33's just debating on doing pucks on original springs or putting on new springs to level out ,any real diff ???
Old Apr 10, 2013 | 06:32 AM
DKehler's Avatar
If you are going to add a bumper or winch to the front then Definately get the springs. I have a 2 1/2" spacer up front and a 2" in back with 33"'s. I go mild rock crawling and think it works just fine.
Old Apr 10, 2013 | 06:47 AM
Billbikes's Avatar
The springs will give greater wheel travel, but cost a bit more. The pucks are simple and inexpensive. They pretty much keep the stock ride on the highway.
Old Apr 10, 2013 | 06:58 AM
Morris4x4Center's Avatar
Sponsoring Vendor
You get what you pay for. Best to go with the Springs. You would need a back space of 4.5 or less so there is no rubbing on the inside.
Old Apr 10, 2013 | 08:07 AM
hooper's Avatar
Get the springs, you can add spacers to the springs if you get heavy bumpers and not lose any lift.
Old Apr 10, 2013 | 08:23 AM
demtek9's Avatar
I did the TF leveling kit and the new discos wore out in 6 or 8 months. I spoke to TF at EJS in the vendor booth and they said to expect 18 months out of them under normal use. The spacers are good, but it's not a long term solution for disco replacements. Get some with servicable joints. I moved up to a 2.5 Rock Krawler kit with new adjustable disconnetcs since then, so you may end up doing it again.
Old Apr 10, 2013 | 02:09 PM
Rock Krawler Suspension's Avatar
Former Vendor
A lot of people that go with a spacer lift at first end up upgrading to a coil lift sooner then later. A coil lift will gain you more performance then a spacer lift will any day! Give us a shout if you have any questions about any of our products, good luck with the build!
RK
Old Apr 10, 2013 | 03:58 PM
Boverton's Avatar
I went with spacer and the Teraflex leveling kit because I did not want to invest a lot of money right now. My 33's turned out nice but I also trimmed my fenders. I want a new highrock stub bumper now and might wish went with new springs. Oh well.
