Rear Cargo Storage as Cooler
Old Apr 10, 2013 | 09:31 PM
EdsJunk's Avatar
Default Rear Cargo Storage as Built-in Cooler!
So has anyone used that plastic bin under the carpet in the rear cargo area as a small cooler? There's a drain hole under the plastic sleeve and if you drill a drain hole in the plastic removable bin (with a matching stopper) you can easily drain the melted ice. It sorta insulates due to the small air pocket between the body and plastic bin, sort of like a tervis tumbler cup. I'm thinking of using some of the spray foam to insulate it better...
Just wondering if you guys have done the same? It's just another way I like to use normally unseen wasted space as something you wouldn't expect to find.
ID:	445501   Click image for larger version
Old Apr 11, 2013 | 03:08 AM
tlminh's Avatar
Man, AGAIN, you are just at a whole other level than us . . .
Old Apr 11, 2013 | 03:11 AM
FDHog's Avatar
LOl! Some of these ideas crack me up.
Great idea if you're not driving anywhere. Would think that heat from muffler would cause ice to melt quick. I always carry a PolarBear 24 soft cooler.
Old Apr 11, 2013 | 05:43 AM
Phishy's Avatar
Don't go up or down a hill! Would think the water would slosh right out of there, that lid doesn't exactly make a tight seal.
But I love the idea, though I keep stuff in that spot, tools, bungees and such.
Old Apr 11, 2013 | 10:18 AM
tuffysJKwrangler's Avatar
Blah might want to leave it in your Sports car then! lol! Its worthless without the Beer!
