Rubi spring/shock swap
Old Apr 11, 2013 | 09:32 AM
JK07DJ12's Avatar
Default Rubi spring/shock swap
i'm thinking about swapping out my 07 2dr JKX springs/shocks for 4dr rubi's... will i need to change/add anything to do this? plan to add spacers to level front and then 33's...
Old Apr 11, 2013 | 09:43 AM
gunbo75's Avatar
In the long run you wood be happier with a2 inch coil lift from: Teraflex it comes with everything you need and you can still use the Ruby shocks. Then if you're ever down the road add a winch and a bumper then all you have to do is add a puck up front and to be level again.welcome to the forum
Old Apr 11, 2013 | 09:51 AM
JK Inspired's Avatar
Better yet, go with the coil and shock swap for probably $140, along withe JKS ACOS, and spend less money than you would for the super stiff TF coils by themselves.
Old Apr 11, 2013 | 10:04 AM
JK07DJ12's Avatar
the rubi takeoffs are stated to only have 1300 miles on them, $160 delivered... how much should the adj spacers run?
Old Apr 11, 2013 | 10:41 AM
Rocky Clymer's Avatar
I hear folks only report about 1/2 inch increase in lift from the Rubi springs....might want to do some research here or on other forums before you spend the bucks.
Old Apr 11, 2013 | 11:22 AM
JK07DJ12's Avatar
i read on a spring rate comparison thread that 4dr rubi springs off jk optioned w/ both tops n tow pkg gave 1 1/2 - 2" when added to 2dr soft top... is this BS?
Old Apr 11, 2013 | 12:49 PM
PM sent to ya
Old Apr 11, 2013 | 03:03 PM
Originally Posted by JK Inspired
PM sent to ya
255/80 18/59s with one inch pucks
Old Apr 11, 2013 | 03:12 PM
JK07DJ12's Avatar
looks great, thanks!
Old Apr 11, 2013 | 03:47 PM
JLsJK's Avatar
Have you seen the "Lets Solve The Stock Springs" thread??? Search it, if you haven't...
