Bed liner vs plasti dip
Old Apr 11, 2013 | 06:14 PM
jlfuksa's Avatar
Default Bed liner vs plasti dip
Fixing to black out grill and hinges. What would be more long term hassle free, and what would be the best brand as far as being uv protected. Don't want that black lookin gray after a long hot summer..... Thanks!
Old Apr 11, 2013 | 06:21 PM
JK_R&D's Avatar
I bedlined mine last winter. Seems to be holding up well. Lightly sanded the grill and hinges. Put on a coat of primer. 3 coats of duplicolour bspray bedliner, the aerosol cans you can buy at the store. Also did my step bars. Seems to be holding up very well. After a year, (and once you clean it) everything is still nice and black. And the colour and texture matches the look and feel of stock black plastics on the jeep. Plasti-dip is something some of my truck buddies have used, and its fine, really easy to do, easy clean up. But its not anywhere close to being as durable. The main thing is that it takes no time to re-do your plasti-dip job. So you can put on a fresh coat every year to keep the colour bright. Personally i like the bedliner better though[attach=config]445932[/attach][attach=config]445933[/attach][attach=config]445934[/attach][attach=config]445935[/attach]
ID:	445932   Click image for larger version
ID:	445933   Click image for larger version
ID:	445934   Click image for larger version
Old Apr 11, 2013 | 06:26 PM
Irish Bullfrog's Avatar
Bedlined is permanent, plastic dip is temporary.. Plastic Dip is a very cheap way to see if you will like it first.. 5 bucks a can so its a very cheap way to see if the looks fits your persona... If you like it, make it permanent.. All that said, my grill has been dipped for 6 months and zero issues, my rims were done for 8 before I lifted and made a change.. The rims are still flawless and I used the shot out of them... On a high wear area like door entries, dura liner is better... But, I have no complaints at all on the dip and I can remove it if I change my mind... WIN...
Bullfrog
Old Apr 11, 2013 | 07:18 PM
kh202's Avatar
Bed liner for long term. I personally like the texture of rustoleum over the duplicolor
Old Apr 12, 2013 | 01:55 PM
jlfuksa's Avatar
Ya I already have the wheels bed lined, from previous owner, will prolly stay with it n use the liner for grill n hinges. Thanks fellas just needed a opinion from someone who done it
