Lange power top hoist
Old Apr 12, 2013 | 04:07 AM
danh63's Avatar
Default Lange power top hoist
Going to probably start the install tonight or tomorrow. I have a 13 ft high ceiling any tips or tricks anyone want to share??
Old May 26, 2013 | 09:49 AM
Cdwright's Avatar
How did it go? I just got mine in the mail.
Old May 26, 2013 | 10:10 AM
Surf City Dan's Avatar
Hit the studs..
Old May 27, 2013 | 04:29 AM
Brightwhite's Avatar
I would be curious to hear about his experience as well.
I bought the same hoist and have 13' ceiling in my garage.... It was a nightmare.
The instructions were god awful. The hardware provided was cheap crap. The design was poor in a few areas. I was not impressed at all...
However, it works, and it works well. I can get my top on and off all by myself in around 15 mins by the time I remove the torx bolts and freedom panels, latch it on, and everything else.
I did improvise and replace a lot of the crappy hardware, and probable over engineered it some. I would suggest that others do the same.
One word of advice. Measure, measure again, measure a 3rd time, then a 4th...and write everything down. I caught a few mistakes that would have caused me to have to disassemble the T-assembly because I made it too narrow. When I caught myself, I was thankful I am so anal about doing things.
Here are some pics...
ID:	462014   Click image for larger version
ID:	462015   Click image for larger version
Old May 27, 2013 | 06:09 AM
oriffx's Avatar
I've had one for two years...observations...
1. Yes, the instructions suck. They couldn't be worse.
2. Absolutely hit the studs. Don't mount it on anything except the studs. Use a stud finder. Use 4x4 or 4x2 if necessary.
3. As previously said. Measure a thousand times before drilling. Set up is a PITA. Not easy at all.
4. Out of the box, it looks like a piece of crap...
BUT...
It works. It's held up perfectly and has not failed. Very convenient. One man job to get hardtop off. A must have!!!
ID:	462028   Click image for larger version
ID:	462029   Click image for larger version
Old May 27, 2013 | 06:36 AM
danh63's Avatar
Not bad at all. you for sure need a counter weight for the front of the top
