35" Fierce Attitude M/T Tire Pressure?
Old Apr 12, 2013 | 10:33 AM
wells1123's Avatar
Default 35" Fierce Attitude M/T Tire Pressure?
I just got these and am trying to figure out what tire pressure gives best ride? I have a 3.5in Teraflex lift. Any help would be great. Thanks
Old Apr 12, 2013 | 11:43 AM
havochaos's Avatar
When I did mine 28psi was perfect for them, but I would still run a chalk line to be sure.
Old Apr 12, 2013 | 11:45 AM
afpilot82's Avatar
JK-Forum Ambassador
Start at about 30 psi, do a chalk test and adjust from there.
Old Apr 12, 2013 | 12:26 PM
XTJake's Avatar
Former Vendor
Afpilot,
Anywhere between 25-30 seems to be where most people run their tires at. The best way to find out is a chalk test. Simply
1. Drive to a flat area. This can be your driveway or the street in front of your house. Just make sure there aren't a lot of cracks, bumps or pot holes.
2. Draw a thick, straight line across the width of the tire.
3. Drive the car forward at least one-full car length.
4. Inspect the chalk on the ground and on the tire. A tire with the proper air pressure should press the chalk line evenly across the ground. This means you'll see the entire chalk line imprinted on the ground. An over-inflated tire will bulge and only the center of the line will touch the ground. You'll only see a small portion of line if this is the case. If you're tire is underinflated, you'll see only the sides of the lines since the middle of the tire is not making contact with the ground.
5. Adjust your tire's air pressure accordingly
Hope this helps! Feel free to PM me with any questions.
-Zach
Old Apr 12, 2013 | 12:50 PM
demtek9's Avatar
I run mine at 28 to 30 lbs
Funny thing: I left Discount Tire with them at 45 lbs and man it was harsh.
Old Apr 12, 2013 | 01:41 PM
afpilot82's Avatar
JK-Forum Ambassador
Originally Posted by ExtremeTerrain
Afpilot,
-Zach
Hmm thanks, I didn't know I asked a question.
Old Apr 15, 2013 | 06:31 AM
XTJake's Avatar
Former Vendor
Haha oops, my fault, that was meant to be a reply to OP!
Old Jul 23, 2013 | 10:57 AM
Tuto's Avatar
Thank you for the explanation.
