I need help!
Old Apr 14, 2013 | 10:29 AM
baker1jeep's Avatar
Default I need help!
I have an 08 Rubicon and bent the front housing. I bought a Tera flex Hd front housing to replace it with. But after the swap my front locker does nothing. It gets power when you hit button and the light just flashes. I opened it up and made sure its getting power and it is. If i use a flat head and pry the ring over it locks. But otherwise it doesnt make a noise or move or nothing when i hit the switch. I know it worked before the swap because we checked it before we started the swap. I really dont want to replace it when i know it was fine. Any help and ideas to try will be appreciated. Thanks
Old Apr 14, 2013 | 10:51 AM
nthinuf's Avatar
Check the plunger position.
There is a diagram in post 4 here:
https://www.jk-forum.com/forums/modi...oblems-213780/
Old Apr 14, 2013 | 11:21 AM
baker1jeep's Avatar
Im pretty sure the plunger is right. If i pull it out some the light stays on or when i pull the ring out it seems to pull out fine with it. However it is a new plunger cause we broke the original one removing the locker the first time.
