Wraparound windjammer on 2007 unlimited 4 dr sahara
Old Apr 14, 2013 | 04:58 PM
black26jk's Avatar
Default Wraparound windjammer on 2007 unlimited 4 dr sahara
Finally got my wraparound windjammer custom fit to my 4 dr. Took the windjammer to an upholstery shop and had them cut the extra flaps that hang down behind the rear seat(i have a tuffy security enclosure) and use that material to add 1 1/2 inches to each side of the windjammer.they cut right where the seatbelts would normally be threaded thru the windjammer and added velcro to the lower 6 inches so now i can remove windjammer without unbolting the seatbelts.like others have done i also cut 2 slits in top plastic above window so i could tighten to rollbar.overall very pleased with results but i will probably have the upholstery shop add a flap in upper corner where windjammer and bikini top almost meet so rain wont pour down inside the surround and also add 1 inch to rear deck cover because it wont fit over the tuffy security deck
ID:	446949   Click image for larger version
ID:	446950   Click image for larger version
ID:	446951   Click image for larger version
ID:	446952   Click image for larger version
ID:	446954   Click image for larger version
ID:	446955   Click image for larger version
ID:	446956   Click image for larger version
ID:	446957   Click image for larger version
Old Apr 14, 2013 | 09:20 PM
JAM85's Avatar
Looks good on your pimp wagon.
Old Apr 14, 2013 | 09:47 PM
Sgt Mack's Avatar
Watch that puddle at the curb!
Old Apr 21, 2013 | 09:53 AM
Fiveofun's Avatar
Looks good. This windjammer is designed to work behind the rear seats normally, correct? The description seems that it's to only protect the front seats, but the installation instructions show the drawing of it going behind the rear seats. What you have done is exactly what I want to do.
Old Apr 21, 2013 | 03:09 PM
JK yeti's Avatar
Either your tail lights are upside down or every jeep owner has there's backwards...
Old Apr 21, 2013 | 03:14 PM
Sporticon's Avatar
Looks good but don't they sell a wrap around one?
Old Apr 21, 2013 | 07:38 PM
GeeHost's Avatar
are those 24s?
Old Apr 21, 2013 | 07:48 PM
RKracing's Avatar
That's pretty cool. Kinda looks like a hummer. Is that the look you are going for?
