This dont look right? Am i wrong?
Old Apr 17, 2013 | 09:09 AM
Kbryant88's Avatar
Default This dont look right? Am i wrong?
So my jk been pulling to the right lately and noticed this today. Look at these 2 pictures and see if I'm crazy or not...
On the first photo, it's my passenger side the sway bar connect looks like it's on the wrong side of the bracket on the bottom (it's outside toward the wheel)
The second photo is my driver side and the link is straight and on the bracket INSIDE of the wheel.
The other side looks like it's bending badly? Is that normal?
Old Apr 17, 2013 | 09:14 AM
Rob 12B1P's Avatar
Not sure if this is the cause of the pull but your correct, that passenger side link should be bolted to the inside. Switch it around and see what happens.
tapp's Avatar
Yeah you should fix the crooked one
Old Apr 17, 2013 | 09:15 AM
Jhouse93's Avatar
Ignore my last post, just switch ot around itll take care of it
Old Apr 17, 2013 | 09:17 AM
Kbryant88's Avatar
Thanks, it amazes me that mechanics make mistakes that this
Old Apr 17, 2013 | 09:30 AM
MMXJKU's Avatar
Also check to see if your axle is centered. From here it looks like the passenger coil might be askew.
Old Apr 17, 2013 | 09:55 AM
Kbryant88's Avatar
How do I do that?
Old Apr 17, 2013 | 10:21 AM
Jonathan_JK's Avatar
Wow they put the swaybar links on wrong? Was this an actual 4x4 shop that did the work? I always do my own work just so I know it's done right. I even do my own oil changes.
Old Apr 17, 2013 | 10:37 AM
pontiac31's Avatar
The one is clearly wrong. It being on the wrong side will not make the vehicle pull in any way though.
Old Apr 17, 2013 | 10:50 AM
Kbryant88's Avatar
Yeah a jeep "specialist" at that. I went to get those c gusset brackets welded on. I usually all my own stuff but I didn't know how to weld so I went there :-(
