Should I be worried about this?
Old Apr 22, 2013 | 04:23 AM
apangala's Avatar
Default Should I be worried about this?
Seems a bit close to the rear tires, didn't know if it would be a problem. Would it be ok to trim it down a bit, like at an angle?Click image for larger version
Old Apr 22, 2013 | 04:29 AM
glock35's Avatar
Search "pinch seam", you will find plenty of threads on how to trim it.
slider_68's Avatar
Just grab your favorite cutting tool and trim it (it only feels wrong the first time) then paint the edges to help prevent rust
Old Apr 22, 2013 | 04:40 AM
bo9roadking's Avatar
Your tire will move backwards as it travels up with the control arm, so it might clear. If it were me, I'd cut it for added clearance.
Old Apr 22, 2013 | 04:46 AM
Jeepstin12's Avatar
Yep. What he said. Just don't cut the pinch seam. I trimmed mine, running 35's and never had an issue. Trimmed just for good measure.
Old Apr 22, 2013 | 05:32 AM
Ryan0260's Avatar
X2. Very easy fix.
Old Apr 22, 2013 | 03:51 PM
Smashboogie 4x4's Avatar
Former Vendor
Absolutely with out a doubt cut it.
Old Apr 22, 2013 | 04:32 PM
TURTLECON's Avatar
Cut cut cut! Or take a big 'ole hammah and smash it in flat
Old Apr 22, 2013 | 04:41 PM
k0260's Avatar
Used a sawz-all, took literally a minute, quick and easy
Old Apr 22, 2013 | 04:46 PM
scooby snacks's Avatar
x2!! I used a little JB weld on the seam and then hit it with some black paint!! Looks factory... Done is less than 30 minutes including getting out and putting the tools away.
