Strange noises after a 2.5" spacer lift with no shocks
So I just had a 2.5" lift installed last Thursday and have probably put 250 mi. on it so far. I have done very little off road since I got it and today for some reason I all of a sudden have an annoying squeaking sound from the rear drivers side. It sounds like the spring is being compressed and just making a noise but I'm not sure?
Any ideas or concerns that need to be brought to my attention?
after my 2.5 budget lift with bilsteins also have a sqeek from what seems to be the rear p[assenger side spring spacer of shock. will douse this area and all rear suspension in grease and wd40
Suggest checking that the spring is seated properly in the rubber spring isolator (top of spring). Also, suggest not using grease or WD-40, these attract grit and may attack the rubber. Silicone spray from an auto parts store that's rubber friendly, and dries, is best.
It may help if someone bounces the suspension with their weight while you're underneath inspecting too.
