Drag Link play (pic)
Old Apr 26, 2013 | 09:08 AM
cadeddie's Avatar
Default Drag Link play (pic)
I am currently hearing some popping noise when my jeep does light articulation, I noticed my drag link has some serious play (pivots about an inch) is this normal? i just changed my lower ball joint on the same side the other day, I don't think I left anything wrong other than the drink link pivoting that way
Whats the best way to replicate the articulation on stand still mode using jacks? can i lift it from a certain point?
Old Apr 26, 2013 | 09:20 AM
mudbug79's Avatar
I think it is ok to have a little play. i am pretty sure it is that way by design.
Old Apr 26, 2013 | 09:28 AM
kjeeper10's Avatar
Vet Army
Rotational is normal. Up and down is not.
Grab some large channel locks and squeeze the joint. Or have somebody 10-2 the steering wheel and watch all the joints. Look for up and down movement.
The drag link TRE to steering knuckle usually is first to go.
Old Apr 26, 2013 | 10:42 AM
cadeddie's Avatar
it does move up and down, do i need to adjust something or replace something?
Old Apr 26, 2013 | 02:54 PM
kjeeper10's Avatar
Vet Army
Stock it's one piece all the way to the adjuster. Then a TRE to the pitman arm.
Stock you will need that whole section of the drag link.
Options
-new
-take off (somebody that upgraded)
-aftermarket HD
I have Synergy's high steer drag link but can be used in the stock location . Click image for larger version
