Soft Top Windows
You need to tuck the tab into the slit in the inner part of the door surround. You need to open your door to do so. It will also be much easier to get that part started first before fully zipping and securing the bottom.
X2- open the door and tuck that tab all the way in first. Leave the bottom tab untucked while you zip. Once zipped, then tuck the bottom and Velcro.
Just as jkrescue described. Here's a video with the entire procedure if you're still having trouble.
http://youtu.be/x2WGr3Wry0c
Hope this helps
