backspacing for 40x13.50
I currently has 3.5 BS and am fine. I trimmed up my end links to help though but with your BS you should be fine
to maintaing full steering up front without rubbing you need to net out to 1.75" bs on the factory axle at 4" of lift. More lift will allow you to run more bs at the wheels. I would suggest some flat fenders as well. Stretching the front will allow you more room for steering as well.
