Where to mease front caster
Old Jun 26, 2013 | 02:38 PM
GunDude's Avatar
Default Where to mease front caster
Can I get pics of good places to measure front caster angle. I know on top of ball joint, but I can not see gauge up there, unless there are diff. ways to do it?
Old Jun 26, 2013 | 02:41 PM
JKphotoshoot's Avatar
I used a digital angle finder on the flat part at the bottom of the knuckle where its flat.
Old Jun 26, 2013 | 03:08 PM
ronjenx's Avatar
Placing an angle finder on the axle will not give you a caster reading.
You have to know how the flat spot the instrument is sitting on compares to the "king pin" angle.
Old Jun 26, 2013 | 03:32 PM
GunDude's Avatar
This is also where I have been using! But, was wondering how accurate it is, as to the top ball joint.
Old Jun 26, 2013 | 03:55 PM
mpkelley20's Avatar
Someone once told me the best way to figure out where to put an angle finder is to get your jeep aligned at a shop and ask if you can go in to place the angle finder on the axle to find the spit that gives you the same reading. Then you always have a good starting point.
