Can you install a drag link flip with less than 4" of lift?
I have the RK 3.5" lift and I was planning on installing a Synergy drag link flip but I keep seeing that you may not want to flip the drag link with less than 4" of lift?
- S
- S
You can definitely install the flip kit and it will work nicely with this set up, providing you have the correct bump stops. PM us if you want a quote.
flipping the drag link at low lift heights can be done just realize that you will loose quite a bit of up travel in your front suspension due to the fact the drag link will hit the frame. Expect to add around 3" of extra bump stop and only have about 2" of up travel unless you are willing to notch the frame.
Flipping the drag link and raising the track bar on the axle will correct the steering geometry that gets screwed up by lifting. Keeping those links as parallel with the ground as possible will also minimize the amount of axle shift you get when articulating the front suspension.
No clearance is gained by doing a drag link flip.
