Safety question
So had DW day before yesterday, did a quick check, and I think I need to replace tie rod bushings, upgrade steering stabilizer (looks to be leaking slightly), and in general get all bolts re-tightened. So here's the question: tomorrow we leave for Pinecrest Lake where I was hoping to do some light wheeling. Should I just leave the jeep at home to get properly worked on, or am I good for this trip if I take it easy? Trip is about 140 miles one way....
Thanks for the advice,
How bad was it? There's a ton of different write ups and everyone has their own idea what it is.
An easy way, is to have someone turn the wheel side to side while you look underneath. Look for loose or moving parts. Check the track bar bracket bolt. Try to move the track bar side to side at the bracket. A lot of times the bolt is smaller than the bushing. Just make sure everything else is tightened up and you should be fine.
If you take it in to a shop or dealer, I guaranty they say ball joints, tie rod ends, steering dampener.
Scared the crap out of me when it happened :-). I went over a construction plate cover on the road when it happened. Did the check and nothing seemed lose or moving where it shouldn't. Track bar bolts were larger than my basic tools (up to 19 mm and 3/4 in) so couldn't check the torque on them. Sounds like a weekend project when I get back, and start one item at a time. Thanks.
