Do I need to cut Rubi Rails????
Old Sep 8, 2013 | 11:01 AM
Yuriy's Avatar
Default Do I need to cut Rubi Rails????
I just installed 285/70/17 Duratracs, and the distance between the wheel and the rail seems too small. I looked up online and people seem to be cutting rails only with 35" tires. Do I need to cut mine, or I should be ok? I don't do any crazy off-roading or rock crawling, but I want to make sure If i go camping or something I will not damage the tire.
Thanks in advance,Click image for larger version
Old Sep 8, 2013 | 11:04 AM
TJM12's Avatar
Looks like you need some lift and adjustable rear control arms.
Old Sep 8, 2013 | 11:05 AM
Yuriy's Avatar
I do not have any lift, but I do plan on putting 2.5" in the near future. So, once I lift it, I will be OK?
Old Sep 8, 2013 | 11:16 AM
TJM12's Avatar
Yes, you should be fine.
Old Sep 8, 2013 | 11:20 AM
Yuriy's Avatar
Thank you very much!
Old Sep 8, 2013 | 02:46 PM
Bonedoc's Avatar
You should be fine. The tire actually moves backwards as it travels up. The control arms cause an arc of movement, not straight up.
Old Sep 8, 2013 | 03:47 PM
SpicedCrusher's Avatar
I'd trim it. I have 2.5" and mine was still very close. It's easy and you won't have anything to worry about after.
Old Sep 9, 2013 | 02:47 AM
Yuriy's Avatar
Thanks again, greatly appreciate the input!!
Old Sep 9, 2013 | 05:44 AM
Rob 12B1P's Avatar
You need to flex it out and see if its going to rub.
Old Sep 9, 2013 | 10:27 AM
Looking at that pic I wouldn't flex that even on a curb. It will rub for sure. Take off about 1.5", spray the cut and pop the end cap back on and your good to go.
