Water level vs differentials
Old Sep 9, 2013 | 05:21 PM
jkwade's Avatar
Default Water level vs differentials
I was out trying to muzzle load hunt yesterday. In s fl we are very wet right now. Anyways, I have a 4 in lift with 35 inch tires. The top of my axles are at 18 in, the bottle of the doors at 28 in. I spent a lot of time going in and out of 20 to 24 inches of water, once maybe to 28 inches in a hole. I have not extended the breather tubes on my axles.
Based on others experience, do I have to change the diff fluid, or not, due to water intrusion in the breather tubes?
Thanks
sent from my phone
Old Sep 9, 2013 | 05:27 PM
familytime's Avatar
JK Forum Regional Rep
If your seals are in good condition you're fine
Old Sep 9, 2013 | 05:45 PM
jkwade's Avatar
Excellent. That's the easiest solution. Any other thoughts out there?
sent from my phone
Old Sep 9, 2013 | 05:49 PM
k0260's Avatar
For peace of mind through any amount of water, install a small band clamp on each breather hose at the diff for added water security
Old Sep 9, 2013 | 05:51 PM
HiHoSilver's Avatar
Did you out axle seals in the front? If you did then you are fine up front... The back is different... They are open and if you went in water above the hub then I would change! Even if you have a doubt i would change it! Better safe then sorry and I played in Florida mud for a few years in my jk and take it from me... It isn't fun to find chocolate milk in your differential!
Old Sep 9, 2013 | 05:58 PM
ronjenx's Avatar
Thanks
sent from my phone
There is only one way to know for sure.
Open the fill hole and look at the oil. Maybe even open the drain plug and drain a liitle out.
If it's still pure oil, no need to change.
If it looks milky, clean it all out, fill with clean oil.
Old Sep 10, 2013 | 02:00 AM
Matthewd5's Avatar
Thank you
You always have the best info and tips!
Matthew
Old Sep 10, 2013 | 03:57 AM
jkwade's Avatar
That sounds like the thing to do. I'll be doing that this weekend.
sent from my phone
Old Sep 10, 2013 | 08:03 AM
Mark Doiron's Avatar
sent from my phone
While down there, ensure your breather tubes are still connected. If you didn't do something to extend or reroute, they may pull off the nipple (hate when that happens).
Old Sep 10, 2013 | 01:15 PM
RubicAn11's Avatar
Wouldn't the water be on top? If the two separate water and oil? Unless you drove it. Got it hot then checked the fluid. So you Wouldent be able to tell just by draining it out. Water would be on top because there is less?
