35x10.5 tires
Old Sep 24, 2013 | 03:25 PM
BigMoe's Avatar
Default 35x10.5 tires
Pea anyone know if any tire manufacturers make a 35 in tire that is narrower than the standard 12.5 width tires that are out there? I would like to mount 35's on either 17 or 18 in rims but want them to be manageable in winter snow and keep decent mpg.
Old Sep 24, 2013 | 09:20 PM
iiM RuSHiN's Avatar
Never heard of that, but if you want a narrower tire you could look into metric equivalent to a 33 or 34 that may be narrower
Old Sep 24, 2013 | 09:53 PM
Rippicon's Avatar
I am running 35/10.50-17 Super Swamper Radial TSL's on mine.
Name:	Flex small.jpg
Name:	Flex 2 (1024x768).jpg
Name:	Flex 1 (1024x756).jpg
Old Sep 25, 2013 | 03:33 AM
Canvas's Avatar
Veteran: Navy
Try looking at a 305/70R/18 which will give you a 34.4 inch tire.
Old Sep 25, 2013 | 04:48 AM
familytime's Avatar
JK Forum Regional Rep
Most tire companies still make narrow tires,but may be limited in the types
Old Sep 25, 2013 | 04:55 AM
Sahara Lee's Avatar
BFG MT T/A KM2 in 285/75R17 measures 33.9" overall diameter and 11.3 overall width.
or
BFG also has a 255/80R17 (pizza cutters) that are 33.3" diameter and 10" overall width.
BFGoodrich Mud-Terrain T/A KM2 255/80R17
Old Sep 25, 2013 | 06:05 AM
TJJK's Avatar
TSL and SSR ARE 35x10.5/17. ALMOST went with the SSR, but did the KM2 in a 285/75.
Old Sep 25, 2013 | 06:22 AM
Chefbrujo's Avatar
Curious.. Why would a narrower tire be beneficial or more manageable in snow? I would think the larger contact patch would be better?
Old Sep 25, 2013 | 06:45 AM
snakeyes76's Avatar
Thinner cuts through the snow better and has the weight distributed on a smaller contact patch for better traction. Never heard of a 10.5" measuring 35 tall. Most MTs won't be great for winter driving unless they're siped and grooved.
Old Sep 25, 2013 | 06:46 AM
jrod250's Avatar
In deep snow, yes. But on a thin layer of snow like is usually found on the road, thin tires will be get better traction because they will bite in better. Less surface area means more pressure per square inch of the contact patch.
