Brake lines hanging after 2" lift
Old Sep 24, 2013 | 04:59 PM
Thorrrrrr's Avatar
Default Brake lines hanging after 2" lift
I've had my '09 JK for less than a month. Bought it from a dealer - previous owner installed a 2" lift. I brought it in to my local speed shop to have a hitch installed and they noticed that it was missing brackets to hold the brake lines that extend to account for the lift and keep them from just hanging there.
The dealership is trying to back away from this since they didn't do the lift. And they don't know what lift it is. I'm thinking they have to make good on this...
I'm having the speed shop fab the brackets - it's apparently easier for them to fab them than to find the brackets that should have been installed in the first place.
I don't know anything about lift kits - but I do know that the brake lines are taking the paint off the chassis and it has to be done. Any thoughts? Is there a good reason that the previous owner didn't install them?
Thanks!
Old Sep 24, 2013 | 05:28 PM
nthinuf's Avatar
Several companies sell extension brackets. Or many of us just spent $5 at a local hardware store and made our own. I used fence menders that already have holes drilled in them, just bent them a bit to get the lines back under the frame a bit and then hit them with some black spray paint I had on hand, so it was a quick and simple bolt-on.
Old Sep 25, 2013 | 02:46 PM
Thorrrrrr's Avatar
Thanks. I guess, no matter what, it's minor anyway.
Old Sep 25, 2013 | 03:28 PM
fultonromero12's Avatar
You seriously paid someone to install a hitch? Like the one that attaches to the back frame??
Sent from my iPad using JK-Forum
Old Sep 27, 2013 | 03:59 PM
Thorrrrrr's Avatar
Ummm... Yes. Yes I did.
Old Sep 27, 2013 | 04:26 PM
jeep-creep's Avatar
^^It's your choice if you install parts etc, to each their own. make sure you get the brake lines done correctly, and measure for drop on each side.
Old Sep 28, 2013 | 02:42 PM
Thorrrrrr's Avatar
I try to DIY as much as I can. But I know what I don't know, ya know?
Old Sep 28, 2013 | 03:09 PM
nthinuf's Avatar
Can't help with the hitch, but there are a few DIY brakeline extension threads to be found.
https://www.jk-forum.com/forums/modi...nsions-113946/
