Brakes?
Old Sep 29, 2013 | 02:36 PM
Crichard12's Avatar
Default Brakes?
Do I need to upgrade to bigger brakes when I put on bigger tires or can I keep the stock brake kit?
Old Sep 29, 2013 | 02:55 PM
karls's Avatar
"Need" is a very open term. Some people find it ok, some people find it to be hell. Put the tires on and get your own feel for it.
Sent from my DROID4 using Tapatalk 4
Old Sep 29, 2013 | 02:58 PM
Phrogmech46's Avatar
What size tire and wheel combo are you looking at? Daily driver?
Old Sep 29, 2013 | 03:19 PM
familytime's Avatar
JK Forum Regional Rep
We still run the stock brakes with 37's,bigger brakes would help stopping power
Old Sep 29, 2013 | 08:16 PM
Crichard12's Avatar
I'm thinking about putting 33s or 35s on. And yes it's my daily driver
Old Sep 29, 2013 | 08:20 PM
Freewill's Avatar
Unless you plan on some extreme driving, just keep the stock brakes in top shape and understand that your brakes were engineered for smaller tires.
Old Sep 29, 2013 | 08:21 PM
Crichard12's Avatar
Ok. Thanks for the help
Old Sep 29, 2013 | 09:21 PM
r3cluse's Avatar
With 33"s you won't see much of a difference, stock Rubicons come with 32"s. If you get heavy 35"s you might notice a longer brake distance. As long as you don't tailgate or have a chuckle-head with an Alaska license plate cut you off the stock brakes are fine. I'm looking forward to the roads icing over so that the twits that think their amateur NASCAR drivers slide off the road and into trees. But I digress.
I upgraded to the Teraflex big brake system with the bored master cylinder. I'm happy with them and I stop better than stock. I haven't tested them, never measured the stopping power of my stock brakes before the upgrade.
I can tell you that it scares the tailgaters behind me.
Old Sep 29, 2013 | 09:46 PM
matprovo's Avatar
There are a lot of options out there, like everything else it depends on your budget. You can get better pads, better rotors or go with a complete new system that changes out calipers, rotors, pads and cylinder.
I've been running 35" for almost two years with no issues braking. I do plan on upgrading though. I'll change out pads at first and see how that goes and possibly go with the TF Big Brake Kit.
