crack in tie rod threads????
Old Nov 20, 2013 | 02:10 PM
Rob'sSaharaJK's Avatar
Default crack in tie rod threads????
Is this triangle crack normal ...my guess is no, but could use some advice on if this will be ok or needs replacement.Click image for larger version
ID:	512110Click image for larger version
ID:	512111Click image for larger version
Old Nov 20, 2013 | 02:19 PM
QRS's Avatar
QRS
Originally Posted by Rob'sSaharaJK
Is this triangle crack normal ...my guess is no, but could use some advice on if this will be ok or needs replacement.Attachment 512110Attachment 512111Attachment 512112
That is definitively not normal. You should consider a new adjusting sleeve.
Not sure for how much it goes at the dealer but you could get Raybestos 425-1065
http://catalogs.raybestoschassis.com...5&catalog=1000
It goes for $34.24 @ Amazon
And make sure to correctly adjust your toe in
Old Nov 20, 2013 | 02:21 PM
14JKU's Avatar
It's hard to tell from the pics but it looks like a manufacturing defect to me. I'd take it back to the dealer and see if it's covered under warranty. Or you could install an upgraded aftermarket tie rod like Synergy or RK.
Old Nov 20, 2013 | 02:26 PM
Thanks for the info...So I guess the question now is better to go with a "HD" tie rod replacement or get the new sleeve and not worry about it?
Old Nov 20, 2013 | 02:54 PM
What about this for a replacement? Would I still need the Sleeve?
Synergy Suspension
GM Style 1-Ton Tie Rod End Replacement
Wrangler JK Unlimited 07+, Wrangler JK 07+
Old Nov 20, 2013 | 02:57 PM
Northridge4x4's Avatar
Sponsoring Vendor
Instead of replacing the tie rod ends if that is what you are planning on doing I am of the opinion you are better of getting the synergy Tie rod.
David
Old Nov 20, 2013 | 03:00 PM
hooper's Avatar
Synergy Suspension
Attachment 512114
If you have stock rims you might need spacers.
Old Nov 20, 2013 | 09:27 PM
QRS's Avatar
QRS
I guess we will need some feedback, I'm sure the synergy tie rod is great, I have their ball joints and drag link but not so sure about the tie rod. Does anyone have any feedback on how this takes some rock beating? I'm just saying this is the lowest part of the jeep so it will be hit hard.
Yeah yeah I know maybe that's why it's HD but won't hurt to have some feedback
Old Nov 20, 2013 | 10:43 PM
kjeeper10's Avatar
Vet Army
Originally Posted by Northridge4x4
Instead of replacing the tie rod ends if that is what you are planning on doing I am of the opinion you are better of getting the synergy Tie rod. David
X10 love the Synergy tie rod. Also rumored RK is soon to drop a new adjustable tie rod with their own ends.
Old Nov 21, 2013 | 09:29 AM
Smashboogie 4x4's Avatar
Former Vendor
We run the Synergy tie rod and bounce off of rocks with it on a regular. The powder coating chips off of it but its not that big of a deal. The tie rod itself is extremely strong and we can give you a good deal on one. Pm us for pricing.
